Slightly off topic - Compressor leak sealing!
ecohouse1
x 3
Unread post by ecohouse1 »
I have a 50litre 2hp SIP compressor which has a leak in the regulator area - I undid the joints and resealed using ptfe tape but accidently overtighted and cracked the union :x
What is the best way to join unions to minimise leakage - is it ptfe or another jointing compound?
Will order a new regulator on fleabay today.
Cheers
Alan
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You could try plumbing loctite. Expensive, though.
Generally, if you're screwing into a cast female housing (as opposed to machined steel or brass) a dry fit - meaning no tape - is recommended. Friction/interference is supposed to do the trick.
x 94
Re: Slightly off topic - Compressor leak sealing!
Unread post by citronut »
i have always used PTFE with no problem,
maybe just use a slightly shorter stilson and leave the 4 foot scafold tube off as well :shock: :twisted: #-o :wink:
regards malcolm
