Turbo diesle Xantia wont start after battery disconnected.
numnuts
Hi all. I have a W reg turbo diesel Xantia. I recently had to replace the drivers door so disconnected the negative terminal, changed the door, replaced the wiring and window actuator (Nightmare). When I cam to start it later it wasnt having it. The needles on the dials go haywire and it just wont fire up or even turn over properly. It doesn't have a keypad, I didn't even think it had an immobiliser! I am not a mechanic, just a DIY'er with a manual. Before I call out an auto electrician, can anybody offer any advice please? Am in Tyldesley, gtr Manchester by the way. Thanks a lot. T
KennyW
- x 165
Re: Turbo diesle Xantia wont start after battery disconnecte
Welcome to the forum numnuts, first for all the guys and girls what kind of diesel is it.
This may help us identify the problem/s
Has it had any previous starting issues in the past.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 1240
I the engine is not turning over properly check the battery connections and also the earth connection on the engine/gearbox, or it could be that your battery is flat/u/s.
spider
- x 77
Perhaps the BSi is corrupted. Have you tried to reset it ?
Andy.
411514
- (Donor 2017)
- x 39
Sounds very much like said as either a bad battery or bad earth, first port of call should be to charge (or replace) the battery and check the engine earth as mentioned, dashboard dials playing up is a sure sign of poor current delivery
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
numnuts
Thanks for all the advice. It was the battery. Charged it up and it fired up fine! Have just started another post relating to a power window issue on the same car. Cheers all!
- x 8457
Excellent
The dead give-away was the gauges going haywire. They always do that on a MK2 when battery volts are very low and in extreme cases the tacho needle can get stuck, buried in the red-line...
Yes, they do have an immobiliser. It's RF activated via a coded chip in the key blade...
