Xantia TPS
lancia58
(Donor 2022)
x 8
Xantia TPS
Unread post by lancia58 »
I have a Citroen Xantia 2.0 16v MK II. At the Citroen service site the TPS catalogue number is 1628 1F at this site
http://www.autosensorberlin.com/index.p ... tro-n.html" onclick="window.open(this.href);return false;
it is written that the TPS is compatible with 1628 1E ( the white one ) . Is there any difference between the 1628 1E and 1628 1F ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: Xantia TPS
I found out that the 1E is for manual gearbox and the 1F is for automatic gearbox (AL4) . Is there a major difference between them, I guess potentiometer resistance ?
Zohar
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The AL4 unit has an extra resistive track for the blue three pin plug on the auto box harness. Can be fitted to a manual car, but not the other way around.
lancia58
(Donor 2022)
x 8
Re: Xantia TPS
Hi Addo
What does it mean "extra resistive track for the blue three pin plug on the auto box harness"
Zohar
addo
x 95
The TPS for automatic cars, looks like a double layer of the manual gearbox TPS - it takes two plugs.
See this link for what the automatic one looks like:
http://www.peugeotlogic.com/workshop/ws ... supply.htm" onclick="window.open(this.href);return false;
lancia58
(Donor 2022)
x 8
Re: Xantia TPS
Do you know and after market source for that TPS ?
Zohar
