C5 Buffeting at speed?
whatdoesthisbuttondo
Unread post by whatdoesthisbuttondo »
Well, Ive had my C5 2L HDI (59 plate) for a few weeks now and very happy with it.
Its taken me this long to get on a road where i could get my foot down and Ive notoced that theres a 'buffeting' at around 80-85 mph. The steering wheel doesnt shake, indicating wheel imballance, but its noticeable. Theres no loose trim, the bonnet catch is tight.
Any thought please?
Citroenmad
x 110
Re: C5 Buffeting at speed?
Unread post by Citroenmad »
Do you feel the buffeting as a sensation through the car or is it just a noise?
It could be imballanced rear wheels, if you feel the vibration through the seats but no the steering wheel.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Thanks for the quick reply!
The rear wheels sounds pretty plausible.I'll get them checked out.
I can feel it but it also feels like the sensation you get when a window is partialy open at high speeds.
Citroenmad
x 110
Can you pinpoint the noise to a particular area? Could well be a poorly fitted door seal.
03 Seat Arosa 1.0S
charentejohn
Unread post by charentejohn »
I have something similar on my Xantia and it is the door trim rubber, sounds like the door is not closed properly and starts at 70mph ish.
I can see on mine the rubber trim has been damaged by people getting in and out. This has put a hole about 25cm long in the tubular bit of rubber which is part of the inner door trim. I will replace it when I have time.
Could be you have something similar, as has been said it may not be torn just not making contact correctly from inner to outer ?
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
Cheers Gents......I will take a look at all 4 door seals at the weekend.
