Filling Eolys reservoir
x 1240
Unread post by Peter.N. »
I have decided to stay with my DPF for the time being but it needs some fluid, can anyone tell me how to go about topping it up, I am only reckoning on puting a litre in for the moment. I have seen kits on ebay, do I need one of these and how do I go about it?
Lighty
x 35
Re: Filling Eolys reservoir
Unread post by Lighty »
The C5 usually just has a lid on it in front of the n/s/r wheel, you simply fill the reservoir through this hole.
This will have no effect on your warning light if it is on though, as you need to tell the Ecu you have put some in by using Lexia. If the car has a green insert in the tank lid, you need Elloys 172, or the cheaper Pats fluid from Euro car parts, or gsf.
If the lid is white you need dpx42 fluid from Citroen or Peugeot only I think.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 1240
Thanks for that. I put the light out or at least the warning off with another members Lexia last time but hopefully I will have mine working soon. I will check the lid colour, its an early one so I think that uses the original fluid.
cachaciero
x 9
Unread post by cachaciero »
Peter.N. wrote:Thanks for that. I put the light out or at least the warning off with another members Lexia last time but hopefully I will have mine working soon. I will check the lid colour, its an early one so I think that uses the original fluid.
DPX42 is what you need Eolys 172 is only applicable to post 2004 cars as far as I know, unless the system has been upgraded :-) Filling it up isn't as easy as lifting a lid you will ned to break into the pipe work and fill it through that.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
x 1240
Oh - right.
