Xsara 2 - air injection pump fault
Haakon
Unread post by Haakon »
Howdy all from Tasmania :)
Have my shiny new Lexia fired up, and have found a depressing array of faults... May be a couple of posts...
This one is about the air injection pump, the little critter that lives in under the left headlight. Seems its out to lunch, with a "permanent fault open circuit" when I attempt to test it. It says to listen for the relay, which I don't hear - any ideas on where it lives...? I'll try that first, then swap out the pump.
Suspect its related to the intermittent downstream O2 sensor fault code - if its not getting the expected dose of air in the manifold, its probably throwing out the o2 sensor readings on occasion. Although of course I could also be losing the cat, as there is a rattle down there...
Anyway - anyone dealt with these things before?
Lighty
x 34
Re: Xsara 2 - air injection pump fault
Unread post by Lighty »
Air injection pumps fail all the time , or appear as fault codes at least.
I think it lives under the wheel arch liner on the left front wing, sort of behind the fog lamp. I find that sometimes if you put battery power straight to it, the motor will kick into life. A new one is expensive, so trace the wires back to the fuse board ( under bonnet) and make sure it is powering from there when you actuate it with Lexia.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Haakon
Cheers, good tip on the resuscitation technique :)
I can't find its relay though... Is it inside the bcu fuse box thingy? I can hear a relay ticking inside that when I test the fuel pump relay with lexia, but cant see one externally...
I would think the air pump relay would still click even if the pump were frozen...
