c5 engine cut out while driving
mick miller
08 c5 engine cuts out while running engine management light and depollution fault have to pull over stop switch off and on ignition and its ok. Sometimes it just goes sluggish while driving and puts up depollution fault and engine management light cones on. Diagnostics say fuel pump relay switch.anyone had this problem was it fuel pump relay or something else.
- x 1240
Re: c5 engine cut out while driving
Could be a faulty in tank pump they are known to give trouble - if an 08 still has one, otherwise its a Lexia job.
mick miller
Thanks for info much appreciated
gary
Under bonnet fuse box can also give similar fault of sudden cutting out /loss of power.
mick miller
Thanks for that info mate
