Panic! xantia immobiliser not allowing code ...
Citroenmad
x 110
Unread post by Citroenmad »
I'm just at an exhaust place in Darlington where they have repeatedly put in the wrong code in. Now the red light is flashing and its beeping but won't allow the correct code. Just had to push it in to get the exhaust done.
I'm hoping it will resetin a few minutes and allow the right code, though Ive not seen them flashing and beeping before :?
I have the Lexia in the boot, luckily, not sure if its any use with the imob. though.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Try disconnecting the battery and waiting an hour - or borrow an ECU with known code from a similar motored Xantia.
Also try getting hold of xmexclusive or Andy (spider) or Wheeler or Birdman - he lists his text number on his website.
Citroenmad
x 110
Re: Panic! Xantia immobiliser not allowing code ...
This sounds serious :(
It's on the lift at the moment. I'll give it a try when it comes down and see what its doing then.
So I take it beeping and flashing of the imob. Lights is not a good thing!
I thought it might just have licked out due to the wrong code being used. However he did say he only put it in twice ...
03 Seat Arosa 1.0S
addo
x 95
As a shortcut you might get away with unplugging and replugging the ignition amplifier - when this fails it creates symptoms similar to an immobiliser lockout.
xmexclusive
Unread post by xmexclusive »
Immo lock out time on later systems is 1 hr.
That elapsed time delay is remembered and stops ticking down for the time a battery is disconnected.
So disconnect to check incase it clears but leaving it disconnected could just extend the lock out time.
Push it into a corner out the way, drink their coffee and be a bit patient.
John
Xmexclusive
Citroenmad
x 110
Thanks John :)
It's been in for about an hour as they are making bits of exhaust for it. It's almost done so ill see if it starts. If not I will be worried :lol:
03 Seat Arosa 1.0S
x 8302
Chris,
[-o<
Citroenmad
x 110
Thanks Jim, obviously worked ... It started straight away after being left for a hour or so. :-D
I knew it wouldn't let me down! :lol:
Exhaust is a good job too, pretty happy :)
03 Seat Arosa 1.0S
x 8302
Citroenmad wrote:Thanks Jim, obviously worked ... It started straight away after being left for a hour or so. :-D
Thank goodness for that Chris =D> :-D
Harry1975
Unread post by Harry1975 »
the standard code for xantias is 1111, so it may have gone back to that
Citroenmad
x 110
Harry1975 wrote:the standard code for xantias is 1111, so it may have gone back to that
Its fine now, it had just locked out due to the exhaust fitter putting in the wrong code too many times. It did have me worried with it beeping and flashing as I dont remember them doing this when locked out.
Ive started it many times since and its still fine :-D
03 Seat Arosa 1.0S
Harry1975
cool im glad it ok , it would of stressed me out. Ive just changed my door locks as the were knackard, after it taking over an hour to get in the car in morrisons car park with the mrs and a lot of shopping, i felt such a prat everyone kept looking at me :(
Mandrake
x 694
Unread post by Mandrake »
Well I'm glad I don't have a keypad immobilizer :lol:
Do any current model cars still use them, or were they a fad which has now passed ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Citroenmad
x 110
They disappeared when the key got an immobiliser chip inside it, so no need for the codepad.
Its a good idea really, as most cars which get stolen now are taken with their keys, as they can not be started without the key. So even if someone has the Xantia key, they can't drive it away. Mind, I don't suspect there is much call to take a Xantia :lol:
03 Seat Arosa 1.0S
