Hi citroen c5 2.2hdi had a guy round to day with a lexia,
he said that i have got a over boost fault, any help how to fix thanks
over boost
Lighty
- x 35
Re: over boost
Overboost can be caused by a lack of vacuum , so he waste gate doesn't open soon enough, look for split vac pipes, there are quite a few. Blocked PDF can cause it, look out for the swirl flaps linkage, these often break also.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Robert12
Re: over boost
ok thanks for the reply,the pdf has bin removed the swirl flap linkage seems ok
found one vac pipe split replaced, but still the same
cachaciero
- x 9
Re: over boost
The swirl valve linkage maybe o/k but the diaphragm in the actuator may well have holes in it causing a loss of vacuum, you really need to measure the vacuum to ensure that there are no leaks.Robert12 wrote:ok thanks for the reply,the pdf has bin removed the swirl flap linkage seems ok
The swirl valve and turbo control are on the same vac supply loss of vac will cause the turbo to go max boost.
Search on swirl valves and my name for more on this subject.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Robert12
Re: over boost
ok will check that tomorrow thanks
