My son's will intermittently refuse to start and the glow plug indicator doesn't illuminate.
Had a bit of a poke around today with no success other than it is starting with no problems
Couldn't locate the relay though.
Thanks spider. Checked the one in the fusebox behind the battery, there is one on the bulkhead that looks too lightweight also some under the dash that also look to lightweight.spider wrote:Behind the battery box / tray or on the rear (bulkhead) side of it in most cases.
It could be the bulb has actually blown, on that year onwards (iirc most of them on the facelift) it uses a temp sensor to determine how long to operate it for, I think if that's faulty it can not illuminate too. Early models were just time controlled (typically 6 to 8 seconds) regardless of engine / air temp.
myglaren wrote:he saw me soldering the broken wires the other night and thought I must have lost my temper with it and heaved a hammer through it.
my African grey does that inbetween non stop talkingmyglaren wrote: succeeded anyway.
citronut wrote:my African grey does that inbetween non stop talkingmyglaren wrote: succeeded anyway.
regards malcolm
