engine under tray
clive singleton
New User
engine under tray
Unread post by clive singleton »
Hi
I have a 2001 synergie HDi
I would like to find a good source for the engine under tray (protection) can anyone help
clive.singleton@warwick.ac.uk
thanks
Clive
x 8457
Re: engine under tray
Welcome Clive. I've moved your post into the correct area of the forum for these sort of questions. The Blogs and Galleries is strictly for nattering about our car adventures!!!
Has yours disappeared then Clive?
I know they are fearsomely expensive from a dealer and that really just leaves the breakers.
Before you get one, often why they're gone is because the fixing studs have sheared or otherwise become too damaged to secure the tray. Check they're good before forking out.
I would expect the Synergie is similar to any other Citroen HDi of that era in that the try bolts to the rearmost part of the subframe using 10mm bolts and at the front to the front valance lip via a couple of studs that take 10mm nuts. It's these front ones that tend to shear off.
I'm sure one of us can get you the Citroen part number of the tray and a picture of how it is secured if that will help.
