hi, my peugeot 206 1.4 petrol 52plate, has an intermittent starting problem. sometimes it will start fine othertimes it will not. when it fails. the air bag light is on and it cranks over ok. it just does not fire.
your help would be much appreciated.
pug 206 won't start
- x 8444
Re: pug 206 won't start
Hi Holly, welcome to the forumholly76 wrote:hi, my peugeot 206 1.4 petrol 52plate, has an intermittent starting problem. sometimes it will start fine othertimes it will not. when it fails. the air bag light is on and it cranks over ok. it just does not fire.
How often does it fail to start? Is it often and what do you or the car do to finally make it start?
Does it just decide to start or no on a whim?
Sorry for the questions but as much detail as possible will help us greatly...
spider
- x 77
To add to Jim's questions:
Do you have more than one key ? , try the other key if you do.
Andy.
holly76
it seems to do it at random. it started fine two days in sucsesion then then it failed again. i tried an hour later and it started. when it failed i tried my other key and it still would not start. i have tried locking up then unlocking and trying again. every time it fails the airbag light is on! somtimes i switch on the ignition and the lights go through there start up, the air bag light will momentatrly go out then come back on. and it will fail to start. i have gone through all the fuses. i found one under the bonnet slightly blackend on the terminal. i cleaned this off and refit a few times to clean the socket. this seems to have made no diffrence.
addo
- Sara Watson's Stalker
- x 95
spider
- x 77
A diagnostic may reveal the cause, my initial thought is the transponder aerial to be honest as they can fail intermittently.
There's no immo light on a 206.
Andy.
holly76
thanks for your help guys
i have not seen any other lights. i have not tried ether spray. but when the air bag light is out, it starts up no problem. when you say transponder aerial do you mean the ring around the lock? would this cause the airbag light?
reading other posts, though not identical seem to blame the comm 2000 unit with the airbag , could this be the cause, is it more than switch gear and a junction box?
addo
- x 95
Quite possibly, the airbag circuit doesn't self-test until it knows the car will fire. Hence the light staying on.
Your transponder aerial is separate to the stalk assembly and as Andy mentiones, can fail. Not that dear new; while you can "swap and pray" as a means to test for failed items, it's best to go new for such pieces as failure isn't always convenient!
0000616068 pre multiplex - Louth's have one on Fleabay at 15 squid.
0000616076 multiplexed (and forever after in 206s) - one for £6.55+P/P at Peugeotcarparts.net
spider
- x 77
I'd agree a new one too. They are not expensive as can be seen. If it came to the workshop with these symptoms I'd probably change this as a matter of course, as its difficult to diagnose when they go intermittent.
Andy.
addo
- x 95
spider
- x 77
Unlikely but I'd not really want to do that myself.
Andy.
holly76
Re:
this seems sensible enough. i have ordered on from peugeotcarparts came to £10.60 with carrage and ene extortonate vat. but i suppose it's cheaper than the comm 2000 unit. i agree with your opinion of ebay parts. some unscroupulos people are selling broken parts after fixing there car.addo wrote:Quite possibly, the airbag circuit doesn't self-test until it knows the car will fire. Hence the light staying on.
holly76
ok, i got the part today, and fitted it. it started before i fitted it. but it still starts after my fiddling! i'll have to try it over the next few days to see if i have fixed it.
holly76
hi guys. it has failed again this morning. the same fault, air bag light staying on and the engine cranking but not fireing. should i bee looking at the comm 2000 unit. or any other sugestions.
thanks for the help so far.
addo
- x 95
It might be worth checking the "Lexia Locations" topic in Super-Stickies, just to see if anyone with a diagnostic machine's within cooee of yourself.
As a related question, when the warning lights stay on like this, does the interior light turn off faster than normal and can you hear an audible click if/when it does?
