Front D-bushes are secured by the bolts on your wishbone P-bushes.
I used rubber grease around the replacement items and anti-roll bar itself, then left the bolts barely nipped up before Citrobics, and a few rolls back/forth under power. Then I lay on the ground beside the running car at normal ride height, to tighten. Not super-easy, but it meant that I hadn't locked in torsional preload.
Anti-roll bar bushes ... Activa mk1
Xaccers
- x 188
Re: Anti-roll bar bushes ... Activa mk1
Have you lubed the front stuts to eliminate them from the source of the noise?
DIY sphere tool
DIY sphere tool
- x 94
there is no need to finaly tighten the rear front arm bush (P bush) with the weight of the car on its wheels at normal hight,
the main thing is to fit the new P bush onto the arm in the correct oriantation in the first place,
although this is correct procedure for the front front arm bush,
regards malcolm
regards malcolm
addo
- Sara Watson's Stalker
- x 95
Xantidote
- x 5
How much higher? Four fingers instead of three? Think I'd be looking at/correcting the ride height issue before getting stuck into anything else.superloopy1 wrote:front ride height seems to have gradually crept higher recently
I had an issue with the rear height on my Series 1 being too high. Never found the reason why. I assume the clamp on the rear anti-roll bar hadn't been tight enough, allowing it to rotate slightly. I reset it, which was a bit fiddly (support the car so it can't drop on you!), and no further problems. Possibly overloaded the car with bags on compost once too often? Could it be that the raised ride height is causing the strut tops to groan in their new orientation?
Martin
1995 Xantia TDLX (deceased
- x 94
Adam i spoz it might be possible for the ARB D bush to move if you accidently move the ARB whilst the bolts are out,
but in saying that as long as you dont alow the D bush to move what you say above would not be necercery, as the ARB should be able to rotate in its bush's when its all bolted up tight,
regards malcolm
regards malcolm
addo
- x 95
lexi
- x 134
I ask this as I notice my Vel D bushes on ARB seem to have the hole slightly enlarged where the bar goes through and is slightly rusty.....no real play with pry bar though.
Is that why you are putting the rubber grease in there? Just trying to get this clear in my mind here
Is that not the way they function and the reason they eventually break up? Do all rubber bushes not take twisting force as well as pistonic movement?the D bush usually clamps hard enough onto the ARB that movement of the bar, twists the rubber.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
addo
- x 95
- x 5668
Ideal image size is either 640 x 480 or for larger images post a thumbnail that links to the full size image.
- x 8333
Those ramps look the business Mike
Just the job I'd say...
Xantidote
- x 5
The major pitfall if you get things wrong is that the car would crush you, but using the ramps should avoid that!superloopy wrote:what are the pitfalls?
My own experience is only with adjusting the rear height, which may be a bit more accessible than the front, and I did this with the car sitting on level ground, albeit having driven it on to 4 wooden blocks of equal height, to increase chassis clearance. As the ride height information given in Haynes is measured from ground level to the underside of the sub-frame in the vicinity of the drive-shafts, you'll find this difficult as the car will be sloping upwards on the ramps. However, if your arch-wheel clearance is 4-5 fingers rather than the guideline of 3 (see other posts on the Forum), then I would have thought you could adjust with the car on the ramps to bring the clearance closer to this 3 finger clearance. I'm assuming here that the 3 finger figure is applicable whatever model of Xantia. The height control mechanism is connected via a short plastic link (approx 2", often referred to as the dogbone) to a clamp on the anti-roll bar. The clamp is eased by fractionally undoing one bolt, and is very sensitive in it's control of the car's height. You'll then have to adjust on a trial and error basis.
I think you'll find there's a few posts/threads on this subject elsewhere on the Forum.
When I first bought my Xantia at 3 years old, I found the front ride height to be too high, and I had a Citroen dealership do the adjustment (took them 1/2hr). Interestingly, I subsequently found the car to handle much better through the chicane of a roundabout I used regularly, where the camber changed significantly on the exit - the ride height no longer topped/bottomed out, and car felt taughter through the exit
Martin
bra.ker
Hi to all,
first of all sorry for my English - I am not a native speaker. Does the noise occur only at low speeds? And in straight direction or also in sharp curves?
MK2 Xantia Activa 2,0 HDi; MK1 Xantia Activa 3,0i
