807 HDI loosing power intermittently
uggers2k
Unread post by uggers2k »
Hi all,
I have a 2003 807 2.0 HDI with 80K.
Recently the car has been driving normally and will then loose power. No warning lights etc is being displayed. If you pull over and stop for a few minutes, start the car and continue, then the car is fine and drives as normal.
This has been happening on/off for the past month or so.
On Sunday, my wife was going down a dual carriage way, when it suddenly lost power and then cut out with smoke coming out the exhaust. The AA towed it home.
Later on, I started the car and it drove normal. The car has been giving me headaches.
Anyone got a rough idea what the problem could be? It is going into the garage tomorrow to be looked on.
Cheers
spider
x 77
Re: 807 HDI loosing power intermittently
Unread post by spider »
Is it complete loss of electrical power (ie: dash goes out etc) as well or just engine ?
If you had not said it was smoking (!) I would of said a possibility is the alternator as the BSI can control the charge rate on some models, trouble is a dying alternator that puts out an occasional spike (which on a non multiplexed car would have no effect in 99% of cases) can cause the BSi to be confused, that may explain why its shutting down. I did see this on the very first 307's quite a bit actually.
Andy.
uggers2k
No loss of electrics. Just seems as though there is no power from the engine. :cry:
uggers2k
Anti Pollution fault, unblock diesel filter, Garage has said its bad and it needs £1200 of work (New DPF, regeneration, etc). I have now decided to scrap it.
x 8441
uggers2k wrote:Anti Pollution fault, unblock diesel filter, Garage has said its bad and it needs £1200 of work (New DPF, regeneration, etc). I have now decided to scrap it.
Hold On! Look in the Citroen section of this forum. There are a mass of threads on this very topic and some offer some guidance for doing away with the DPF and so on. It's mainly for the C5 but it should be relevant to your vehicle as well.
Seems a shame to scrap just because of this when there is a way out...
x 1240
Unread post by Peter.N. »
New DPF on ebay about £150.00 doesn't look difficult to fit + the eolys fluid.
Harlequin
x 24
Unread post by Harlequin »
ill give you scrap money for it! need a new car :D
Simon
