HDI 1400 Boffs....
citroenxm
Fallen Hero
x 70
HDI 1400 Boffs....
Unread post by citroenxm »
Ive a problem with a 1400 8v HDi.... (Its actually a Vid below, NOT a Pic, please click to watch!!)
Rev her up to just above 1200rpm and she smooths out.... and also, apparently when warm it settles down!
Any one any idea what Im looking at here (problem wise, NOT the car make :-D )
Compared to my brothers C3, with identical engine, the C3 feels livler and quicker then this lump above
A very sad...
1994 XM 2.1 d auto
x 5688
Re: HDI 1400 Boffs....
Mine was like that Paul, dud injector.
Lighty
x 34
Unread post by Lighty »
I second that
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
citroenxm
Fallen Hero
x 70
okay.. thanks. . now to work out which it is... lexia here we come. i assume no.1 is at the cam belt end...
A very sad...
1994 XM 2.1 d auto
x 5688
citroenxm wrote:okay.. thanks. . not to work out whichvone.. lexia here we come. i assume no.1 is at the cam belt end...
I'm reasonably sure it is the other end - PSA seem to revers the sequence compared with other manufacturers.
Check the needle lift sensor on #3.
lexi
x 133
Unread post by lexi »
When revved up and smoothed out those units still sound..........awfull! :shock:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8457
Paul, it might be an idea to do a leak-off test on the injectors using 4 pop bottles.
There's a picture of it on here somewhere but basically you disconnect all the leak-offs and divert them into pop bottles. The fullest pop bottle after the test normally indicates the duff injector as it will leak a lot more than the others.
Lexia should show a very high correction factor for the duff one too...
citroenxm
Fallen Hero
x 70
ah jim.. theres my clue for lexia.. HIGH correction figure... ill give it a test either tonight or tomorrow.. otherwise its pop bot time.. lol...
cheers
A very sad...
1994 XM 2.1 d auto
x 5688
x 8457
That's the one Steve :-D
