Breaking Xantia LXTD Hatch
Jetfixer
Unread post by Jetfixer »
My Xantia was front ended by the wife yesterday. Believe it or not Ive already bought another one.
I am planning to break it after removing some spares for myself.
The Engine was fitted two years ago and has done about 70000 total miles (15000 in my Xantia). It cost me £700.
The two pipe hydraulic pump is about a year old I still have the receipt.
The Heater matrix and dosuer valve was replaced last year too.
Contact me if interested in these or other parts.
I also have a spare Injector pump for sale, for those of you who have buggered theirs up with vegi oil.
We live near Manchester.
Mike D
blueboy2001
Unread post by blueboy2001 »
Mike - what are the rear lights like? If they're in good nick are very cheap I'll come and pick them up from you.
May also be interested in the pressure regulator if its in good nick at the right price.
Let me know.
wrinklet1
Unread post by wrinklet1 »
Hi, could well be interested in the doseur valve if its the right one for my car, 1993 1.9TD SX Xantia
andycarter
Unread post by andycarter »
Have you got a 2-button plip key?
I only need the circuit board if you want to keep the lockset intact
pete woods
Unread post by pete woods »
If it had a drivers airbag I could do with the rotary connector.
Am I in luck?
Powerman
Unread post by Powerman »
Hi, Do you have the throttle position sensor on the pump ? I think mine has developed a problem. Its a variable resistor and mine jumps around at the low throttle position. I checked it with a multimeter. This would mean removing it from the pump. The pump may not be so attractive after this.
I live in Stafford..so could pop up the M6.
Cheers
