fuel pump C5
nifas3
fuel pump C5
Unread post by nifas3 »
Citroen C5 2.0 HDI 2001
Hello friends, maybe someone you know what might have happened? yesterday I wanted to clean the fuel tank, disconnected everything drew a cleaning pump, there was nothing. everything is done without disconnected batery? / /?Engine starts sometimes and work 5 minutes sometimes half a minute and then goes off.
looked on as far as weather sucks, no . how I think if pum is broken he does not start ever.
x 8272
Re: fuel pump C5
Generally if the pump is broken the engine will not start at all.
You should be able to hear the pump running and making a low hum for about 5 seconds when you turn on the ignition. It will then stop and restart when the engine starts running.
Then the pump will run continuously until the engine is switched off or if the engine stops.
The pump can be accessed under the rear passenger seat, under a big round rubber plug. Remove it to hear the pump more clearly.
If the pump is very noisy or it is making a nasty noise then it is faulty and must be replaced.
nifas3
Re: fuel pump C5
pump working perfect, i replace from peugeot 406 2.0 hdi
x 2941
Re: fuel pump C5
Have you put enough fuel back in?
nifas3
Re: fuel pump C5
yes is a half tank, Lexia-3 shows this mesage fuel high pressure regulator blocked???
i replace it from diferent car (this car works perfrct)
