Hydraulic Clutch advise
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi
Advise, its not a direct Citroen Part, but as the HDi 110 uses hydraulic clutch I thought I may get away with it.
I need to look at a Hydraulic clutch system which seems to have got air in it...
I started removing the slave cylinder from the gearbox, but as I did, the slave piston started comming out of the cylinder..
What Im asking is, Is this a sign of Air in the system,? Which is expanding as I release the slave cylinder??
A very sad...
1994 XM 2.1 d auto
x 8287
Re: Hydraulic Clutch advise
Not usually Paul, it's a sign that you've not tied up the clutch pedal and the weight of it is just enough to start the slave piston moving...
I've had a few out now and after making sure the pedal is well tied up, never seen this...
Those are a right bleeder to bleed... They're designed as a sealed system. They can be bled but it's not easy...
imperial21
Unread post by imperial21 »
Hi Paul
I have a complete hydraulic clutch system, I could sell you if you get desperate Paul ?
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Deanxm
x 87
Unread post by Deanxm »
it shouldt have air in it unless there is a leak or maybe been tampered with, a lot of systems have bleed valves on the slave, the honda im working on now does, why is air suspected is the clutch dragging?
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
citroenxm
Fallen Hero
x 70
Hi Dean,
the pedal has a sort of spongy feel, and doesnt release the clutch completely... Only just enough to get in gear with bite right at the bottom... Theres No bleed, its a supposedly sealed system, but must have an air ingress some where..
Cheers Imperial, but as I hinted, its not a Citroen im refering to... :oops:
A very sad...
1994 XM 2.1 d auto
x 8287
citroenxm wrote: its not a Citroën im refering to... :oops:
It's not a Rover 75 is it Paul?
But yes, the symptoms do point to air in the hydraulics. As t's not a Citroen I think you may find there's a leak, either from the master or slave that's caused the fluid level to drop so low that air ingress has been permitted. Rovers do this when the save fails and the slave is part of the release bearing so it's a gearbox off job to do it. Some Frauds are like this too, MKIV Festers with the little Zetec for one.
The designer of that idea should have been shot...
Deanxm
x 87
If its not a cit what is she Paul?
EDIT, beat me to it Jim
D
XM Prestige PRV6 92
citroenxm
Fallen Hero
x 70
Ok... All wrong Jim, Its a Renault Espace 1997 R reg, 2.2 td...
Its a sealed system, but luckilly the slave is an EXTERNAL mounted one... however, got a simmilar problem on a Laguna 2 DCi.. but on this the pedal goes down and stays.. I beleve thats a master cylinder problem... however, on those the slave is inside the bell house, so they are gearbox off...
A very sad...
1994 XM 2.1 d auto
x 8287
citroenxm wrote:Ok... All wrong Jim, Its a Renault Espace 1997 R reg, 2.2 td...
Ahh :) Branching out into Renaults now then Paul... Excellent...
citroenxm
Fallen Hero
x 70
Well, they are french... Sarah has a Clio.. and a ADORE and LOVE the Ren 25.. and theres a lot of Clios about!
I also LOVE the Laguna 1 too...
A very sad...
1994 XM 2.1 d auto
