urgent derv help
bad driver
urgent derv help
I have a 95 306 1.9d, have just been offered a 1.9td engine out of 93 bx. I understand this is the same as the 306 td engine. will it go straight into mine without loads of electrical work? I have power steering but unsure if the bx had it, will this make a difference?
alan s
- RIP 2010
- x 6
I'll leave it to one of the Pug pwners who know the car to comment on the fit, however, I have seen a few Pugs & corresponding model BXs and without going into real close inspections, the impression I gained was that they are pretty much the same under bonnet.
The D - TD bit is possibly all that coul cause problems with the extra plumbing although again I really can't senviseage any real big problems.
Regarding power steering, in the case of the BX they don't have a power steering pump as such because they draw the hydraulics for this from the main hydraulic system via what's known as a flow diverter which is fitted on the lower part of the block behind the radiator and naturally have the main hydraulic pump mounted elsewhere off the block.
Alan S
Alan S
alaws
Homer
- x 16
