removing the glovebox on mk1 C5?
phil1969
Unread post by phil1969 »
how do i remove the glove box on my mk1 C5, taken all the hex screws out but still won't budge, what have i missed?
cheers
Phil
SaabC5
Re: removing the glovebox on mk1 C5?
Unread post by SaabC5 »
From memory there are 4 screws on the bottom hinge area and 2 or 3 on the rear/top. Remove the fuse box cover and also the interior light and then you should be able to pull out the glovebox, its quite well in there and requires a good tug to get out.
mlkey
Unread post by mlkey »
There are some torx bolts on the underside edge, the heads face the bulkhead. I know there are definately two but as the previous post says there could be more..
phil1969
thanks guys, found the 2 torx bolts, what a bloody job! more hassle than removing the flap motor. all done, will keep u post on the motor. waiting for part at citroen dealer. £86!
SaabC5
Lets hope they get the correct part, my local Citroen main dealer got me a motor with a brass cog instead of the extended one the first time round!
