Hi
Using the Lexia for engine diagnosis I found the following filed : Can. valve OCR . Does anyone know what does it mean ? What should be the readings ?
Zohar
Can. valve OCR
lancia58
- x 8
Can. valve OCR
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 1061
Re: Can. valve OCR
Do you mean cannister valve OCR ? The OCR (open cyclic ratio) is the duration that the component is switched on or opened for. The reading varies depending on lots of different vairiables like engine speed etc. This is assuming you mean the charcoal cannister electrovalve.
