Buying a C5, is this what i must look out for?
CitroSwede
Unread post by CitroSwede »
I am now looking for a C5 HDI as a nice addition to my Xantia. I have read about some typical weaknesses in the C5:s, but i have some more questions about what to look out for.
An MK1 or MK2 isn't so important, the important thing for me is that it's well maintained and serviced.
Is this the main things to look out for?
-Steering wheel sensor (How to check that?)
-change of particle filter?
-Some axle that can break in the dashboard ventilation (Is it possible to hear if it's bad and eventually going to snap?)
-Rear arm bearings (creaks from the rear? Wanders?)
-Wheel bearings
-Rear window mechanism.
Please fill in if i have missed something! :)
Citroën Xantia HDI -00
Have Lexia..
cachaciero
x 9
Re: Buying a C5, is this what i must look out for?
Unread post by cachaciero »
CitroSwede wrote:I am now looking for a C5 HDI as a nice addition to my Xantia. I have read about some typical weaknesses in the C5:s, but i have some more questions about what to look out for.
Lexia
Mk1 2.2's only MK2's most all
-Wheel bearings
Leakage /weeping from power steering pipes.
Swirl Valves and related vac supply 2.2's MK1 and Mk2 to about 2006.
Radio mk1's check that they can pick up all the stations a known good radio can as there seems to be a lot of failures of the radio which starts with loosing ability to pick up weak stations gets progressively worse.
FAP's Mk1 2.2 and others only way of really being able to check the state of these is with a Lexia.
Would strongly suggest that you look for a Mk2 rather than a Mk1, many, most? of the deficiencys in the MK1 appear to have been fixed in the Mk2.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
