C5 running battery down
x 1240
Unread post by Peter.N. »
Hi Folks
There is a C5 advertised near me very cheap but it apparantly runs the battery flat if its not used for a couple of days, is this a known fault or could it be anything?
It is an LX but is advertised as having cruise control, would that be an option on an LX, not that I particularly want cruise control I would rather have auxilluary heating but I just wondered.
Lighty
x 34
Re: C5 running battery down
Unread post by Lighty »
Split charge relay is the most common problem I have come across, but obviously if it hasn't got a towbar it cant be that :mrgreen:
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 1240
Thanks for that, yes it does have a towbar, any idea how it runs the battery down?
Lighty
x 34
The relay tends to stick on, hence using current constantly. I have had 4 or 5 of these go wrong, as they are usually cheap nasty chinese things.
Citroen C15
Citroen Ami
x 5673
Also, LX doesn't come with cruise as standard.
x 1240
Thanks Lighty and Steve, useful info. I didn't think cruise control was fitted.
SaabC5
Unread post by SaabC5 »
Cruise could have been retro fitted though......
x 5673
SaabC5 wrote:Cruise could have been retro fitted though......
It's available as a dealer option at around £135.
Chris (citroenmad) bought and fitted his own without difficulty.
A Lexia is needed to tell the various ECUs that it is present.
cachaciero
x 9
Unread post by cachaciero »
Peter.N. wrote:Hi Folks
Maybe it is not switching into eco mode, if this was the case all the CPU's would be permanently up and running plus probably a few other bits and pieces. Now I do not know for sure what the electrical consumption is in "nominal" mode but a figure of 3 or 4 amps wouldn't surprise me in 48 hours that's a flat battery.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
