Hi all
Sylv's ZX appears to have a leak from the underside of the pump.
Of course, hers is the DW8 which makes it more involved to remove in the first place. Not a job I particularly fancy doing just yet as I only changed cambelt back in November.
I have read http://www.frenchcarforum.co.uk/forum/v ... =3&t=33751" onclick="window.open(this.href);return false; and note Kim's comments.
However, on the underside of the pump (it is difficult to see) there appears to be a drain plug with a copper washer. Am I right on this point? It feels as though it is leaking from that sort of area generally.
Leak on Lucas Pump
- x 8457
Re: Leak on Lucas Pump
Who's Kim? Look, what I get up to at the weekend is my businessRhothgar wrote: I have read http://www.frenchcarforum.co.uk/forum/v ... =3&t=33751" onclick="window.open(this.href);return false; and note Kim's comments.
Don't touch that plug Roger, it's not a drain plug... It's one of the bolts that holds the distributor head in place,,,
Lucas pumps tend to leak from the top and the diesel dribbles down and looks as if it's coming from the bottom.This is a very common fault.
A straightforward resealing kit will do the job. Get on to Merlin Diesel and get one ordered up. It used to be a job that could be done in-situ until they armoured them but the good news is that a Lucas is a lot easier to de-armour than a Bosch...
Rhothgar
- (Donor 2026)
- x 222
Thanks for the prompt and full reply, Kim.
I promise not to tell no-one!
Love, Regina
Love, Regina
- x 8457
Rhothgar
- (Donor 2026)
- x 222
Leak on Lucas Pump
Mystery solved! Ir's that damned solenoid in the front of the pump again! Needs new seal and some thread lock.
- x 8457
Rhothgar wrote:Mystery solved! Ir's that damned solenoid in the front of the pump again! Needs new seal and some thread lock.
That's good news Roger
