Xantia Heater Blower and Rear Screen
wornelly
Unread post by wornelly »
Right, my Xantia heater has decided to work periodically, where as it comes on sometimes was working fine a couple of days ago, now it doesn't sometimes usually when its cold, but I have noticed that the heated rear screen don't work either when this happens, press the heated screen switch and put the heating on and then theres a click from the fuse box, so i'm guessing it's possibly the relay if they are combined, so Q1 does a relay run both screen and heater blower and if it does where is it and can i get another one ????? many thanks,
Nelly
x 1240
Re: Xantia Heater Blower and Rear Screen
Unread post by Peter.N. »
It sounds as though the power supply is intermittent to the heater, I believe there is an underbonnet fuse, there is in the XM anyway, and the fuseholder overheats and causes a poor connection.
x 1479
Mk1 or Mk2 Xantia?
Mk1 - the ignition switch is burning out, needs a relay inserting to take the load off the switch. I've got a wiring diag if you want.
MK2 - there is already a relay, but the power supply to it can ao awry sometimes. can give instructions as to how to check / rectify.
Post back if Mk1 or 2 and we can advise how to proceed.
x 1240
Oh, I had forgotton about the ignition switch :oops:
wornelly
Yh that would be great if u could I only need the car for a few more weeks but it needs to work that long, many thanks RichardW :-D
Xaccers
x 186
Unread post by Xaccers »
wornelly wrote:Yh that would be great if u could I only need the car for a few more weeks but it needs to work that long, many thanks RichardW :-D
Is the grill seperate to the bonnet? (ie a Mk1 Xantia)
Or is the grill part of the bonnet? (ie a Mk2 Xantia)
We need the information.
DIY sphere tool
wornelly
Yh mine is the mk1 xantia
