Xantia lower TB cover Bolt Size 1.9TD 99'
nick90
Unread post by nick90 »
can anyone tell the size and thread for the two bolts which hold on the lower timing belt cover
did the Tb and can not find the bolts despite being very careful
thanks
nick
x 8263
Re: Xantia lower TB cover Bolt Size 1.9TD 99'
M6 I believe....
x 1475
This being Citroen, they're M7 seemingly....
05
0307 21
02 WASHER-SCREW
7X100-12
Not sure what the 100-12 bit refers to....
not that dear from the dealer:
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT
0000030721 WASHER-SCREW 0.34 GBP 0.41 GBP 0.41 GBP
Xantidote
x 5
Unread post by Xantidote »
M7? That might explain why 11mm spanner required. I'm assuming bolts are same size (diameter) as the awkward sod at the rear of the top cover
Martin
1995 Xantia TDLX (deceased :( )
x 1475
Correct, the one at the back is listed as M7x100-38.
I think the 100 part is the thread pitch - 100 equating to 1mm, and the other part the length (in mm presumably). So the bottom ones are much shorter, which makes sense....
