p0026 fault code
john1doherty
p0026 fault code
Unread post by john1doherty »
Hi all
just bought a c8 for my sins,its a 2.2hdi exclusive 2004 and there is a few wee issues namely-
"anti pollution filter" warning light comes on intermittently , goes off of its own accord ?
"fuel additive minimum" warning light on constant
engine management light was on and when read gave code p0026-Intake Valve Control Solenoid Circuit Range/Performance (Bank 1) the engine management light has been put out and so far has stayed out but the fault wont clear.
according to the man i bought it off (a doctor) the timing belt went at 80000 miles and the engine was replaced with new water pump and timing kit so no worries there for a while i hope.
Any information and ideas are most welcome
Lighty
x 35
Re: p0026 fault code
Unread post by Lighty »
There is a plastic vacuum capsule on the end of the inlet manifold, looks like a black ballcock. Check this as the little ball socket breaks and falls off the inlet flaps.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
bill196510
Unread post by bill196510 »
Sorted, was electro vavle to turbo, lol.
C5 2.2 hdi 2003, called it oliver reed, drinks like him :(
Good on fuel now, lol.
rfhspares
Unread post by rfhspares »
Hi, I have the same code on my c8 2.2hdi.
What valve did you change? I have 2 vacuum valves under the windscreen and 2 more near the passengers wheel arch and the swirl valve under the windscreen also. I was going to change the swirl diaphragm but you say you charge get 1 of these turbo electro valves, which one?
