Sorry, another question I'm afraid!
My new Xantia makes a bit of a rattle under acceleration then once over 3k it stops. I've read various things ranging from it just being something the HDi does, through to worn injectors. My old Xantia HDi didn't do this at all which makes me wonder whether it could be the latter. I'm guessing replacing injectors is an expensive affair and not really one I would like to contemplate on a relatively cheap car. On the other hand the noise is bugging me a bit and ideally I'd like it sorted. Any suggestions most welcomed!
Xantia HDi noise under acceleration
- x 1240
Re: Xantia HDi noise under acceleration
Injectors are the most likely cause, they leak internally and this upsets the injection timing but unless its very bad I wouldn't worry about it. There are quite a few secondhand ones on ebay for not a lot of money.
citroenxm
- Fallen Hero
- x 70
Annoying more then anything.. I wouldn't bother.. The HDi injectors are a Two Stage injector, which is cut off after 3k revs.. the idea of two stage is to smooth out idle, by injecting a small amount in the first stage near TDC, then injecting the full amount in the second stage..
Mine has ALWAYS done it, for the last 45k.. I just turn the radio up... she still gives me 43mpg avereage, with a tuning box fitted too...
Buying some off ebay is ALSO a tricky thing, you cannot tell externally what condition they are in.. The safest way would be to get another set assumed buggered, and send them for refurb, but be warned... They ARE expensive to do.. IM sure (but not positive)
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1240
Yep you are right Paul, about £100 on ebay
Synth1983
citroenxm
- Fallen Hero
- x 70
thats because old xanti td use mechanical injection not electronic two stage and have a completely different in compatible fuel system... so sorry.. no is the answer...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
charentejohn
Found a good 'what could be causing my diesel problem' here while looking for injector prices http://www.uniteddiesel.co.uk/diesel-engine-smoke.php" onclick="window.open(this.href);return false;
A good writeup but no prices, need to fill in a form to ask for them, may do that sometime but I prefer a price up front.
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
