Hi I need a wiring diagram for a petrol pump on a 1.8 16 v Xantia, the manual only shows fuel gauge . Ive just change a knackard heater matrix, and the passager foot well was about an inch deep with water, ive taken out carpet and its drying ,took rubber plugs out so it can drain away. One of the wire connectors was all covered in white fluffy crap, ive cleaned it, and used needle files to make a good contact, but still pump dont work. ive direct test pump and works fine .ive checked and changed fuse to be on the safe side. So cant really work out why its not working, Fuel gauge looks like its working ( but dont hold me to that ). im leaving it for a few day incase theres water (wetness) stopping it working. But all else fails will re wire, as car is only a work house, so not to worried about it being perfect, a bodge will do, So can anyone help PLEASE
Thanks Harry
HELP AND WIRE DIAGRAM NEEDED FOR FUEL PUMP
addo
- Sara Watson's Stalker
- x 95
Harry1975
Re: HELP AND WIRE DIAGRAM NEEDED FOR FUEL PUMP
its a mark 1 1996, its the fuel pump not working , tested pump it works tested fuse its ok, so dont know why its not
