Fitting a Xantia steering wheel
Dommo
x 20
Unread post by Dommo »
Just a word of warning, when the haynes manual says to only use approximately 25 lb ft of torque when tightening the Xantia steering wheel nut (or torx bolt on s2 cars), listen to them. I just tightened mine on using a small ish socket wrench and heard a cracking sound, obviously I provided a bit more torque than I was meant to and it has cracked the steering wheel spline, so rather than being an O shape its now a ( ) !
That'll be a trip to the scrappers tomorrow then for a replacement before work.. There's a Xantia V6 ( :x ) in my local one, I've been nabbing all sorts off it. Just need the electrovalves and I'll be happy it's stripped of most good bits, barring the engine and gearbox.
Edit - I should probably provide a bit more info here about the failure, the spline the wheel goes onto is tapered, and is obviously (always is obvious afterwards isn't it!) designed to be a snug fit after only 25 lb ft of torque, going too mad on it forces the spline on the wheel to open and fail as mine has. DOH!!
citroenxm
Fallen Hero
x 70
Re: Fitting a Xantia steering wheel
Unread post by citroenxm »
I NEVER listen to the haynes.. its full of bull... I use my common sense.. and tighten it just so the wheel doesn rock anymore.. Its a lock nut so shouldnt undo by itself..
A very sad...
1994 XM 2.1 d auto
x 1481
Unread post by xantia_v6 »
Dommo wrote: There's a Xantia V6 ( :x ) in my local one, I've been nabbing all sorts off it. Just need the electrovalves and I'll be happy it's stripped of most good bits, barring the engine and gearbox.
Is that a mk1 or a mk2 V6?
Citroenmad
x 110
Unread post by Citroenmad »
citroenxm wrote:I NEVER listen to the haynes.. its full of bull...
I was following a Haynes earlier to remove a C5 front bumper, it was not of much help :x
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Dommo
x 20
Mk2
In this case folks it seems the Haynes manual was right and I was wrong, I know it's unusual for that to be the case :lol:
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Dommo dont suppose you want to remove the slip ring for me? ;)
and/or can i grab the spare set of wheel buttons? i broke my ribbon cable last week :(
Dommo
x 20
jgra1 wrote:Dommo dont suppose you want to remove the slip ring for me? ;)
I will if I get chance, I only have a short time available there due to needing to go to work!
I can't remember if the ribbon separates, don't suppose you have a leather mk1 wheel do you to swap?
x 1481
Dommo wrote:I can't remember if the ribbon separates, don't suppose you have a leather mk1 wheel do you to swap?
Just remember that the MK1 wheel changed in 96/97 when the airbag ECU moved from the steering wheel to the console. The early ones have the airbag warning light on the steering wheel, the later ones on the dashboard. I have been looking for a good late MK1 leather wheel for a while...
jgra1
(Donor 2021)
x 36
hi Dom, dont worry, you would have been pushed for time..
the slip ring has 2 plugs at the wheel (one for airbag, one for stereo controls etc) and 2 other end.. down by lower column.. but the upper and lower column shrouds have to come off.
the buttons and their ribbon are all one, and can be tricky to get out of the wheel without breaking the cable.. right now the buttons are more important than the slip ring
anyway, hope you got the wheel off ok :)
Dommo
x 20
I have the slip ring jgra. Pm me regarding postage and such! It's a hydractive slip ring you realise?
Unfortunately my broken mk1 wheel WAS a good late leather one :(
Anyway, my car is now sporting a mark 2 wheel, glad its sorted.
Cheers.
Xantidote
x 4
Unread post by Xantidote »
Dommo wrote:Just a word of warning
Thanks for the warning :) - would never have occurred to me that the spline could split. Glad you've sorted it
Martin
1995 Xantia TDLX (deceased :( )
citroenxm
Fallen Hero
x 70
Dommo wrote:I have the slip ring jgra. Pm me regarding postage and such! It's a hydractive slip ring you realise?
Cheers.
S2 wheel on an S1 car, so you have an EXTRA horn button now, as in the Air Bag...
I have a collection of S2 XM (so S1 Xantia) leather steering wheels in the shed, need to go through them and sort them out, and see whats what... However, Im not sure if air Bag check light is on the wheel, or on the dash. IIRC Early S2 XM's are on the wheel like the Early Xantias..
John,
Ive had a WHOLE S2 HDi Xantia in for breaking due to 285k and a blown gasket between the water and oilway... The car IS complete.. ready for me to start on..
I can check the wheel controls for you if you like!
A very sad...
1994 XM 2.1 d auto
jgra1
(Donor 2021)
x 36
Paul have pm'd you :)
Chris570
x 36
Unread post by Chris570 »
What's the trim level on the HDi ;)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
citroenxm
Fallen Hero
x 70
is that to me chris???
i may start a new topic on her... but anyway.. shes an Sx..
A very sad...
1994 XM 2.1 d auto
