Xantia front foglamp retrofit question. Solved!
mirafioriman
Unread post by mirafioriman »
On my 1994 series 1 Xantia I now have the front foglamps fitted. They are wired up, the switch is fitted and I've fitted the missing fuse.
However they don't work. Do they have a relay I need to fit? If so can anybody tell me where it is etc so I can return to the scrapyard and get one?
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
mirafioriman
Re: Xantia front foglamp retrofit question. Solved!
There should indeed be a relay. Fitted one and they still didn't work :( Turned out I had a bad connection and they're now working :)
Just the trims to paint now (they're currently in grey primer)
