Any problems with 306 handbrake cable?
x 5679
The handbrake cable on my son's '97 R 306 D-Turbo has snapped. Any known problems with replacing it? (drum brakes rear).
x 94
Re: Any problems with 306 handbrake cable?
Unread post by citronut »
dont know of and prob with the cables Steve, but if its bendix mechanisum in the drums they do suffer with the tinny stainless steel pawl/blade going awall,
this blade when in place locks the the ratchet of the self adjusters to stop it unwinding,
to obtain the bled/s you have to purchase the adjuster kit fromn pug at between £50 and £60 :evil: :evil: quid dependant on modle,
regards malcolm
spider
x 77
Unread post by spider »
That's true although the 206 adjuster clip likes to fly off when you adjust it with the drum off :(
The cables are handed left / right and I expect different for disc / drum rear.
No known issues, only the drum really.
Oh, watch cable length, the estate and saloon vs hatchback cable is longer I think. I do remember something about the estate cables being different at least as in needed to be a fraction longer. Pattern ones usually are not long enough sometimes. I think the cabrio cable is different again (or its the saloon one)
Andy.
x 5679
Thanks guys.
Will get one ordered. Why he can't just shove a brick under the wheel beats me.
Car is going the journey in May (MOT due and too many things to fix).
He's taking his motorcycle licence and aims to have a GSXR600 by May.
spider
x 77
The other side may still operate.
Do they not leave it in gear then ? , I've always left everything in 2nd, figuring it was enough to hold it but also better than leaving it in 1st / reverse due to ease of potential breakage if it was hit. Not wanting to start a "leave in gear or not" thing though.
Andy.
x 5679
It's quite dead.
He does leave it in gear but where he lives now is on a hill and he's a bit wary.
There is a level parking place outside but the idiots next door usually manage to take up all three places with two cars.
If it got hit it would be doing him a favour :)
spider
x 77
Fair comment. Had not thought about hills. :D
Some do that here too, have seen them repeat. Six cars (four houses, same family etc) and they take up about ten spaces, purposely moving several at once to leave a "not quite" gap (about the size you could *just* get an old mini in if you really tried) , then moving two or three up together to get another one in, expanding them when they go out. You'd have to see it to believe it, its almost a qualifier for antisocial behaviour although to be fair they are all paying their road tax etc... End of rant. :)
Andy.
