c5 estate lights in boot
speedy1409
Unread post by speedy1409 »
Both lights in my boot don,t work.
Because those lights only work if the boot door is open, there must be a problem with sensor. I also think so, because the car does not warn me if i drive with open boot.
Can anyone tell me where can i find the sensor, or at least a pressure point for it...maybe its just poor connection.
thx
x 1240
Re: c5 estate lights in boot
Unread post by Peter.N. »
The XM has a switch containing a ball bearing which runs up one end and closes the contacts when the tailgate is lifted, if the C5 uses the same system it will be inside the tailgate somewhere.
x 1056
Unread post by wheeler »
The boot open switch on the C5 is an integral part of the latch. Another possible cause is broken wires where the wiring loom goes from the body to the bootlid ?
speedy1409
Thanks wheeler. The wires were indeed broken at the hinge.
