Another ZX 1.9D question...
RussellF97
x 10
Unread post by RussellF97 »
Hi All,
The book says to "Apply sealing compound to the end camshaft bearing caps", but it doesn't make clear what sealant to use. Is a thin smear of silicone OK, or should I use something else - or nothing? There didn't seem to be anything there when I took the cam out.
And I was impressed by the quality of the machining... and surprised there were no bearings, the cam just running in the head - must be a hefty oil supply! 8-)
Phil
Phil
Indecision is the key to flexibility...
jacko47
Re: Another ZX 1.9D question...
Unread post by jacko47 »
hi phil silicone is ok only use a little as not to block oil circulation the caps are in line bored which means they are machined with head so are matched to head thats why such a good fit i also apply a bit of silicone to oil seal outer edge not lip cheers chris
RussellF97
x 10
Thanks for that Chris. Silicone it is then...!
Phil
