Cirroen c5 estate rear window problem.
gaz black
Unread post by gaz black »
Hi
Can anyone help on here i have just bought a citroen c5 estate on an 04 plate.
the problem being the rear window does not open and the rear wiper is not working either!
i have checked the fuses and also taking off boot panel to check plugs/cables and there doesn't seem to be anything wrong.
Any help would be great and thanks in advance.
Gaz
Wenglish
Re: Citroen c5 estate rear window problem.
Unread post by Wenglish »
This request for repair has been asked several times before. Do a search on the internet, with the Heading you have used here and full instruction will turn up some even have pictures. I did the whole job in one hour, mind the next one I do will be my fourth. Any probs PM me.
Try this link below
http://users.skynet.be/sky83161/sven/openingc5.pdf" onclick="window.open(this.href);return false;
gaz black
Re: Cirroen c5 estate rear window problem.
Hi wenglish thanks for the tip and sorry it took so long to reply.
I will have a go at it and see if I can get it goi g again.
Thanks again Gaz
