timing belt tensioner question
aerodynamica
x 215
Unread post by aerodynamica »
Next q. Is the plunger on the timing belt tensioner pressurised by the engine oil? I was checking the tb condition and note that after a longer rest the belt tension feels slacker. Do I need to adjust it?
Graeme M
HDI
x 7
Re: timing belt tensioner question
Unread post by HDI »
Answer, no !
The reason for the belt having less tension when cold than hot is down to thermal expansion of the engine.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
aerodynamica
x 215
Hmm, I felt it had too much slack (up to 10mm) but when tighter, seemed nice and tight
Graeme M
x 94
Unread post by citronut »
the rule of thumb is whilst tensioning a cam belt you should be able to just turn the longest run of belt (usualy from the front of the cam sproket to front of crank sproket) 90 degrees,
so if you do this whilst the engine is cold it should be fine,
regards malcolm
