Washer fluid in footwell
MonkeyMark
Unread post by MonkeyMark »
Hi all,
When I try to spray the rear washers nothing happens, but water pools under the carpet on the drivers side. I presume a pipe has come apart or split. Where would the pipe enter the car and what would be the best way to get at it?
Cheers, Mark
Happy(ish) C8 owner.
x 8457
Re: Washer fluid in footwell
Mark, it comes in through the A pillar behind the wing and then runs up the A pillar to the roof cant rail and then along that to the C pillar before dropping down to the tailgate or across to the middle of the rear of the roof depending upon model.
Some have a non-return valve in the line and yours might have this just under the dash.
MonkeyMark
Thanks fof that Jim. I presume it enters on the drivers side? Hope its not too hard to get to. Half day at work today so intend to have a look, weather permitting.
