152C Seatbelt trigger 2 open circuit
evilclive
x 3
Unread post by evilclive »
My air bag light is flashing, and Lexia tells me it's 152C - Seatbelt trigger 2 open circuit.
Anybody got any useful thoughts - eg is it driver or passenger side, and which bit to dig around in?
2001 Xantia HDi.
cheers,
clive
DickieG
Monaco's youngest playboy
x 33
Re: 152C Seatbelt trigger 2 open circuit
Unread post by DickieG »
Normally that will be the drivers/offside on a Xantia.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
cachaciero
x 9
Unread post by cachaciero »
Why does open circuit wiring under seats come to mind? not that I know anything about Xantia's.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
DickieG
x 33
cachaciero wrote:Why does open circuit wiring under seats come to mind? not that I know anything about Xantia's.
The seatbelt buckles have pre-tensioners which form part of the airbag system, invariably what happens is that the connection plug under the seat gets separated.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
CitroSwede
Unread post by CitroSwede »
I had the same problem.
Carefully disconnect the white/yellow connector under the seat and spray it with some electrical contact cleaner.
Then, with a bit of luck it should work again.
The electrical cleaner does not contain any lubrication, and will not leave any residue.
Do not clean with anything else, or you will probably have contact problems again.
Citroën Xantia HDI -00
Have Lexia..
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Agree with you on the non-lubricating contact cleaner! So many people throw WD-40 around the place like it's a perfect cure.
I pulled the plugs apart (they simply click together), and soldered the wires where each part of the plug had only been crimped. After reassembling the plugs, they look perfectly original and have 100% conductivity. Of course this was done after disconnection of the battery, module plug and grounding out the pyrotechnic contacts.
evilclive
x 3
A month or so later, I finally got round to looking at this. Nothing obvious, so I played with the connectors a bit and it's no longer complaining. Rather less of a disco light effect on the dashboard :-)
Thanks to all for the advice, esp. which seat to check.
