Xantia back arm bearing replacement.
mirafioriman
When I was doing my suspension work on the Xantia I noticed that the drivers side back arm bearing is failing.
I've done a couple of BX back arm bearings so it shouldn't be a problem to do. On the net I've found a kit from AEP for around £30
http://www.aepdirect.com/rear-arm-beari ... ory_id=754
Is this an ok part for a good price?
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
DickieG
- Monaco's youngest playboy
- x 33
Re: Xantia back arm bearing replacement.
I can't speak for that particular kit as I've only bought arm kits from GSF who IIRC sell SKF one's (they worked fine) the one in that link photo looks to have all of the required parts from what I can see.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8397
AEP normally sell only OE or good stuff so you should be fine. If you do get this one it'll be interesting to see how makes it.
It's a jolly good price...
Rhothgar
- (Donor 2026)
- x 221
Do Xantias exhibit the same canted in look when the rear arm bearings fail and also at what approx. mileage?
I'd like to know as I am scheduling work to do on mine at the moment after having replaced discs and pads all round with genuine Citroen parts yesterday.
- x 8397
Yes, and they can also creak like an old door when going up and down and show odd tyre wear. Mileage? Depends on many factors. I guess the best factor is how well greased they were when the car was made. Some greases had a terrible habit of drying out and this is the normal cause of wheel bearings dying...Rhothgar wrote:Do Xantias exhibit the same canted in look when the rear arm bearings fail and also at what approx. mileage?
- x 5672
They do indeed but as far a mileage is concerned it appears to be very variable.
The C5 is the same and I have no evidence of it on mine at nearly 150,000 where others have failed at around 50,000, same with clutches and DMFs.
It seems to be that cars that have had their rear axles submerged in floods and fords fail soon after due to corrosion from water ingress as the bearings are insufficiently packed with grease.
Perhaps the same applies to cars used in very wet conditions for short trips as they could be drenched but not heat up enough to disperse the water.
- x 8397
That conjurers up an image Stevemyglaren wrote:It seems to be that cars that have had their rear axles submerged in floods and fords
- x 5672
mirafioriman
Thanks for all the advice. Mine has done over 150,000 not sure if it haqs ever had them done though. The passenger side seems fine but not the drivers side.
When I've saved up I'll order that kit then
Rhothgar
- (Donor 2026)
- x 221
Thanks for the additional info. Funny that because Haynes states they are designed to be maintenance-free for life!
mirafioriman
I guess they are maintenance free but like everything else they wear out eventually and need replaced.
- x 94
dont see how they can say maintenance-free for life, spoz it depends on what/who'z life,
as the seals must wear and then allow damp/water into the bearings, so it must be the life of the seals then,
regards malcolm
regards malcolm
- x 5672
The life of the bearings
When they fail, their life is over
addo
- Sara Watson's Stalker
- x 95
lancia58
- x 8
Hi
I need to do the same job for my Xantia. Is there a thread that describes how to do it ?
Zohar
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
