One is a permanent fault on the front Hydractive Electro valve. The car is in permanent hard mode. I have done the diode mod and both front and rear valves are showing electrical continuity and a resistance of 4.5 ohms. If you do citrobics, during a rise or fall the rear valve momentarily switches and the car goes into soft mode for a second or so before going back to hard.
Does the ECU have any way of knowing what the electro valve is doing other that knowing there is electrical continuity? If electrical continuity is the only test, and from the plug it looks like that is OK does this suggest it is and ECU problem?
Rory
