ZX 1.9D valve adjusting shims...
RussellF97
x 10
Unread post by RussellF97 »
Are they still available? I presume they are a dealer part only. I have emailed a Citroen dealer in Somerset near where my brother lives (who can send them on to me) but haven't heard anything back yet - they are probably still laughing! :lol:
Apologies for the continuing stream of questions about my ZX, but it's the first time it's gone seriously wrong in the three years I've owned it - and it's a bit of a learning curve! :shock:
Phil
Indecision is the key to flexibility...
Lighty
x 34
Re: ZX 1.9D valve adjusting shims...
Unread post by Lighty »
It was very hard to get shims even when ZX was still a current car, like most dealers, they will probably just not bother getting in touch again.
When we have an issue, I get mine remachined, as they usually need to be made smaller. Just calculate by how much, and most engineering co's can do this for a reasonable cost.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 94
Unread post by citronut »
any good engine reconditioners will have a selection of shims they will probably sell you some,
or go to a breakers and whip a few cams off any car with an XUD lump so you can get a selection together for your self,
regards malcolm
x 1240
Unread post by Peter.N. »
When I had a BX head repaired after a camshaft failure I got the firm to do it for me. The problem is that they are not marked with the thickness so you have to mic them and as you don't know what sizes you will need until you do the job, rather than have to buy an assortment I let them do it.
If you could get a scrap head you would probably have enough of an assortment to do it yourself. Any XUD head should do.
RussellF97
x 10
Many thanks for the replies, folks.
I only have a problem with three inlets, two gaps being .229mm and the other being .305mm which is twice what it should be. Are these engines very sensitive to incorrect valve clearances?, because if all else fails, the original shims will have to go back until I can sort it out at a later date.
Phil
x 1240
If it doesn't rattle I wouldn't worry about it. The usual problem is the clearances being to tight - that will cause lack of compression.
x 2938
That's really not the correct answer Peter N, if he has the the thing stripped best do it right first time, 'near enough' is what caused the downfall of the UK car industry. :)
spider
x 77
Unread post by spider »
I thought the sizes were marked on the shims ?
Although I'd never trust any markings anyway and always measure them.
Andy.
RussellF97
x 10
The sizes may have been marked on the shim but if it was, it's no longer visible so don't know what it originally was.
I've miked them so know what sizes I need, but if they are NLA then as it was running OK (apart from the blowing head gasket that is) before I took the head off, I guess it should run OK with refitting the original shims. It's just that I would have liked to set it up properly, but don't have a problem with reusing the original bits.
When I head back to the UK I'll have to start whipping the cams off any XUD motors I come across to build up a stock of shims! 8-)
Phil
x 1240
Gibbo2286 wrote:That's really not the correct answer Peter N, if he has the the thing stripped best do it right first time, 'near enough' is what caused the downfall of the UK car industry. :)
I didn't realise it was stripped, I thought he was trying to do it in situ - obviously didn't read the post properly, as usual :oops:
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
I have managed to modify some shims before.. using wet and dry i think.. takes a while :)
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
In wouldn't bother looking in a breakers for shims as most of the one's fitted to engines when new are around the same size, been there tried that.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 2938
I've got a few in my 'glory box' if you can wait for the post to arrive I'll send them to you but it'll be hit and miss if they are the correct size.
RussellF97
x 10
Thanks one and all for your replies: I have heard back from the dealer and they are going to check with Citroen if the shims are still available - watch this space!
Phil
spider
x 77
If its any help (maybe) the XUD from a 306 are listed as this, I suspect they are all the same, bear in mind Peugeot part numbers:
Code: Select all
0906 92 01 ADJUSTING BALL
          EP 1,65
0906 91 01EP 1,725
0906 90 01EP 1,8
0906 89 01EP 1,9
0906 88 01EP 1,975
0906 87 01EP 2,05
0906 86 01EP 2,125
0906 62 01EP 2,225
0906 63 01EP 2,250
0906 64 01EP 2,275
0906 65 01EP 2,3
0906 66 01EP 2,325
0906 67 01EP 2,350
0906 68 01EP 2,375
0906 69 01EP 2,4
0906 46 01EP 2,425
0906 70 01EP 2,450
0906 71 01EP 2,475
0906 47 01EP 2,5
0906 72 01EP 2,525
0906 73 01EP 2,55
0906 48 01EP 2,575
0906 74 01EP 2,6
0906 75 01EP 2,625
0906 49 01EP 2,65
0906 76 01EP 2,675
0906 77 01EP 2,7
0906 50 01EP 2,725
0906 78 01EP 2,75
0906 79 01EP 2,775
0906 51 01EP 2,8
0906 80 01EP 2,825
0906 81 01EP 2,85
0906 52 01EP 2,875
0906 82 01EP 2,9
0906 83 01EP 2,925
0906 53 01EP 2,950
0906 84 01EP 2,975
0906 85 01EP 3
0906 54 01EP 3,025
0907 07 01EP 3,05
0907 08 01EP 3,075
0906 55 01EP 3,1
0907 09 01EP 3,125
0907 10 01EP 3,15
0906 56 01EP 3,175
0907 11 01EP 3,2
0907 12 01EP 3,225
0906 57 01EP 3,25
0907 13 01EP 3,275
0907 14 01EP 3,3
0906 58 01EP 3,325
0907 15 01EP 3,35
0907 16 01EP 3,375
0906 59 01EP 3,4
0907 17 01EP 3,425
0907 18 01EP 3,450
0906 60 01EP 3,475
0907 19 01EP 3,5
0906 61 01EP 3,55
0906 93 01EP 3,625
0906 94 01EP 3,7
0906 95 01EP 3,775
0906 96 01EP 3,85
0906 97 01EP 3,925
0906 98 01EP 4
Andy.
