307sw 136 hdi brake servo failure
x 1240
Unread post by Peter.N. »
Hi folks
I am staying in Sevenoaks with a friend until tomorrow and he has a brake problem with his 307, when cold the servo sometimes doesn't work until it gets warm. Any suggestions?
Lighty
x 34
Re: 307sw 136 hdi brake servo failure
Unread post by Lighty »
No common problems as such, but it depends on what you mean by warm.
If it works after about 30 seconds of engine running, I guess it has a leak, in the vac system, most probably the servo its self.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 1240
It only happens in very cold weather, it will clear after several operations of the brake pedal or if you leave the engine running for about five minutes but it is apparently getting worse i.e. it happens when its not so cold, doesn't happen in normal driving though, only when you first start.
spider
x 77
Unread post by spider »
As others have said probably vac leak. Could be vac pump itself failing too.
Andy.
x 1240
OK thanks all. I'm home now.
