HDI Issues
Lighty
x 35
HDI Issues
Unread post by Lighty »
Ok all you clever chaps, could you cast a brain cell or two over this problem please.
Engine is actually in a Pug Boxer van, but its the same as any other application, its a 2.0 . The van starts and runs fine, but after a little heat is in the engine , lets say 2 miles, if you take it up to 3000 rpm ish, the engine rattles really badly as if it has dropped a valve :? If you gradually let the revs drop off, the noise goes away, and a little smoke may be emitted, perhaps unburnt fuel, it certainly smells a tad rich. The more you do this the worse it gets,it will even completely stop sometimes, but if you drive steady at no more than 2500 rpm its fine.
The Lexia seems to lag a little on this vehicle, ie about a 1 second delay on parameter readings, but I have noticed (no fault codes by the way) that when the crucial noise appears, the pre injection advance works its way up to 32 degrees and then switches immediately to zero. I wonder if this is related or the ecu is just doing that because it senses a problem.
This is the only thing I can find, fault wise.
So far the van has had,
High pressure pump (changed under warranty because the 6 month old one was leaking)
Injectors (one at a time with used, but no difference detected)
Crank sensor
Cam sensor
Oil changed (was possibly a little overfull, made no difference)
Checked valve springs for breaks ( not 100 % they are ok but reasonably sure)
Drained all fuel, and replaced ( possible petrol contamination)
Air flap in the intake manifold removed about 1 yr ago.
Non of these things has made a deal of difference, any ideas, I am pretty flummoxed now, so all suggestions gratefully received.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
DickieG
Monaco's youngest playboy
x 38
Re: HDI Issues
Unread post by DickieG »
Hydraulic valve lifter?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1240
Re: HDI Issues
Unread post by Peter.N. »
Is it rattling on all cylinders or just one?
Lighty
x 35
Re: HDI Issues
Hard to tell, but I would say all of them
Citroen C15
Citroen Ami
addo
Sara Watson's Stalker
x 95
Unread post by addo »
In other marques I might suggest the cam variator has digested its innards.
x 1240
Re: HDI Issues
Sounds like a timing issue, does the noise vary with throttle opening i.e. does the noise go off if you are going down hill with the throttle closed?
Lighty
x 35
Re: HDI Issues
noise still happens off throttle and down hill
Citroen C15
Citroen Ami
x 1240
Re: HDI Issues
Sounds like a mechanical noise then, could possibly that the camshaft timing is out.
