02 307 2L HDI 110 Dturbo anti pollution fault
mark21td
Unread post by mark21td »
Hi All not been on for a while but I need some help.
I'm getting an "Anti pollution fault" plus "ASR/ESP not working" coming up, this will go out at times and stay off for maybe a day but will come back.
It's going into limp home mode giving reduced power.
Ive tried swapping the vacume valves (the two at frunt of the sump in the middle) this worked for a few hours but was probably a coincedence.
Not had it long and ran fine until I give it a real good boot full reving the engine quite high.
Can anyone help.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
Lighty
x 34
Re: 02 307 2L HDI 110 Dturbo anti pollution fault
Unread post by Lighty »
The ESP/ASR fault will come on purely because of the engine fault, it could be loads of things, but check the connection at the very back of the engine under the wiper scuttle.
The intake pipe to the engine joins here, and they can come apart, causing a misreading of air through the maf.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
mark21td
Ah, funny you should say that, that bit of ducting was apart but the truble has started after I put it back togeather.
I'll chech the connections in that area to see if I desturbed anything.
