Are V6 & VSX front fenders interchangeable?
Ozzie Kuma
Unread post by Ozzie Kuma »
My VSX is in good nick, not so the V^ & I want to swap the fenders & doors. the fenders "seem" to be a little wider, ( the wheels are a larger size so I assume they need more space) does any one know if they ( & the doors) are interchangeable ? Is it a big job?
Just thought I'd throw that in to fly the Ozzie flag!
98 Xantia V6 MK2
95 Xantia VSX
x 5634
Re: Are V6 & VSX front fenders interchangeable?
Can't answer your query but that is a very dynamic photo. One of yours?
Ozzie Kuma
yep,.. "nippers" ( young life guards ) playing , jumping of the rocks into the sea @ Colloroy.... oh to be so young.
98 Xantia V6 MK2
95 Xantia VSX
Citroenmad
x 110
Unread post by Citroenmad »
I doubt your 95 VSX will have the right front end, unless its a 2.1TD or TCT?
The V6 has a winder front end, wider/more flared wheel arches and a front bumper to suit them and with a deeper lower grill. The V6 (and 2.1s and TCTs) have a wider front track so the extra body width is needed.
The parts should fit but it wont look right
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I have a smidge of "destress" time this weekend after 12 hours of concreting yesterday. Ping me if you want another set of eyes on the situation.
Ozzie Kuma
Thanks mate,.. you may have noticed I am trying to get the matrix in... that is more important than the fenders, see other post... it needs to go IN - UP & ACROSS 20mm. I just can not do it by pushing. IS there another locating bolt on the left? If there is I'll just pull all that stuff off from in the engine bay & undo that bolt ( I have to reconnect the two pipes anyway)... then I would not need another set of eyes. If there is not another bolt, YES please.... Sunday, home all day.
98 Xantia V6 MK2
95 Xantia VSX
addo
x 95
I can give you a few hours then; no probs. Will phone around 0900H in the morning and we can work it out from there.
Ozzie Kuma
much appreciated.. I have taken the coolant tank off & can see the "other " bolt,.. it is near impossible to get at without removing al the hydraulic pipes... look forward to your call... an hour should do it... as long as I can get it relocated & the coolant pipes connected in the correct way,.. I can do the rest..
98 Xantia V6 MK2
95 Xantia VSX
Ozzie Kuma
addo, no need to call or come over, found the other bolt, should be able to do it myself now , thanks anyway.
98 Xantia V6 MK2
95 Xantia VSX
addo
x 95
Works better than you might imagine; I have crook guts from too much good food and not enough sleep!
