Xantia v6 dash reassembly
Ozzie Kuma
Unread post by Ozzie Kuma »
I have just replaced my heater matrix but can not reposition the dash. It is a few cms out to the right.
Can someone assist with any trick to reposition it please.
I assume there is another locating bolt ( the same as the one with the fibre washer on the right) on the left side of the firewall behind all the hydraulic pipes, should I undo that too?
I have connected the "matrix to firewall" bit to the matrix, should I put it in position on the firewall first?
Any hints gratefully received.
Image.
98 Xantia V6 MK2
95 Xantia VSX
lexi
x 133
Re: Xantia v6 dash reassembly
Unread post by lexi »
Don't know the answer mate but : Why do women not buy a guy chocolates when he completes a matrix change?? :-({|=
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Lighty
x 34
Unread post by Lighty »
Not sure on your dash issue, but you should completely refit the heater box before putting the dash back in for sure.
Always check that your water pipes will go onto the matrix as well, because I had a few Nissen matrix's that were faulty and the pipes would not fit on fully, and I had to remove them again. Since that I will not fit Nissen, only Valeo.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Not a V6, but shocked to discover this gappy bâtard. Ony mechanics in there before, have been two main dealers and one RR specialist who dabbles in Citroëns.
Mine, too...
Mine, too...
Ozzie Kuma
oh dear, I didn't get that problem, it is about the only thing that didn't happen. Mine is all "ok-ish" at the moment. If you need assistance it is all fresh in my head, just give a yell I'll come help .
98 Xantia V6 MK2
95 Xantia VSX
