hi all..
can you clever people confirm as to weither the hdi oil cooler is the same as the xud td cooler.. and even the same as the petrol xu cooler where fitted??
the taxi has blown hers at 283k.. leaving the header tank full of grey oil water mix.. but the sump is perfectly clear.. so im pretty certain its the cooler...
cheers
hdi / xud oil cooler...
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
Re: hdi / xud oil cooler...
part No.'s for a 1.9TD
1103 G2
NFP
DISTRIB CHAMBER
EP 56,6
- AIR CONDITIONING UNTIL RPO 08007
1103 C9
EP=47,6
- AIR CONDITIONING SINCE RPO 08008
and here is part No. for a HDI 90 the same for 110
1103 N1
DISTRIB CHAMBER
EP 69,2
VALEO THERMIQUE -
- SINCE RPO 08421
( + 1103 J4 END O 08420)
regards malcolm
1103 G2
NFP
DISTRIB CHAMBER
EP 56,6
1103 C9
EP=47,6
1103 N1
DISTRIB CHAMBER
EP 69,2
VALEO THERMIQUE -
- SINCE RPO 08421
regards malcolm
citroenxm
- Fallen Hero
- x 70
so whats that telling me??? yes or no???
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
I'd say its a no...
Possibly just remove it as its not that needed if the car is a light duty taxi. More for the warmer climes and the people pushing the engines hard each day.
Porbably the only over-engineering on the car TBH
Dommo
- x 20
One of its main jobs is to heat the oil up on cold starts (and to then keep it at roughly 80 deg where possible). So on a HDi it is an important item.
xmexclusive
Hi Paul
The internal contents all work the same, capacity will be a little different with each type but should not matter.
Pipe orientation can be different so need a bit of hose altering.
Biggest difficulty can be the oil cooler thickness.
Centre hollow bolt threads are common but needs to be the correct length so recover and swap bolt with the matching cooler.
If you need him out and running as a temporary fix loop the cooler out of circuit.
If you do this then put a loop of hose between the cooler pipes as well to stop the car dumping too much oil through the leak.
John
John
Xmexclusive
citroenxm
- Fallen Hero
- x 70
Well i answered my Q last night on johns response.. the cooler was identical in everything except the water pipe outlets were in opposite positions.. the left one was at the rear the right at the front.. the left one on hdi is at the front because the pipe comes up tight against the altinator mounting bolt and the oil pressure switch.. thats all..
thanks for responses..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
