hello guys
first problem ive had with this peugeot partner in 67k but my advance solenoid is sticking - it manifested its self pretty much straight after i replaced a knackered alternator with a direct part number replacement off a scrap vehicle but tested (and ive retested it since fitting) - the old one died by the diode pack failing and frying the alternator and a few bulbs and fuses....hence my concern about the ECU
i start the engine up and it fires straight off and idles at 850 RPM than as it warms up idles at 1100 rpm - previously it was the other way round - cold 1100 and warm 850
if when cold i gently tap the advance solenoid with a screw driver handle it starts no bother and idles correctly.
ive dug about on the internet and some folk say i need the ecu reprogrammed at a dealer as thats causing the sticking - others say the advance solenoid is dead and other even say that the control relay is dead (but im sure i can hear that clicking when i start - just unless i tap it there is no whirr from the solenoid)
so i figured id come to somewhere that is likely to know all there is to know about these vehicles for some guidance.
thanks guys
1.9l DW8 advance solenoid sticking
top drive
Re: 1.9l DW8 advance solenoid sticking
an it just gets better - drove to the bank to sign the line on my first house and true to form - if it can go wrong it will ....
the exhaust just split right behind the cat ....sounds more like a john deere than peugeot. Am i right in thinking i can just weld in a straight pipe in place of the cat and itll pass mot since a diesel just does a smoke test !
spider
- x 77
It will pass without the cat, assuming the fuel system is OK. A Peugeot dealer will notice the lack of cat though, personally (just in my opinion) I'd use a non dealer for an MOT if you have removed it to be sure.
Regarding the main issue, there's a few things here:
Early engines had mechanical advances on the pump and no ECU (what little ECU there was, was for the EGR)
Later units had an electronic internal advance / retard for the injection timing.
Most (both types) also have post heating too, a microswitch or two on the control lever, this also effects the EGR.
In addition you'll have a waxstat cold start cable too, ensure this is actually working (taught when engine cold, a few mm slack when hot)
I don't think these DW8's had a cold start advance unit, usually only turbo engines have these (screwed into front of pump on Lucas units)
Is the solenoid in question accessible ?
I don't think its that somehow (I could be wrong) as it would run terribly and knock if the injection timing was wrong caused by that being faulty.
Andy.
top drive
looks like that first image - only less rusty - fairly sure its a lucas pump
the solenoid i tapped is right on the front just below the pump under a rubber cup - with 2 rubber hoses going into it.
once i tapped it , there was then a buzz(solenoid sounding) when preheating that hasnt been there since alternator change.
kill engine and leave it then restart - no buzz , turn off ignition open bonnet , tap the solenoid = engine starts mint
logic says change solenoid but then having to reprogram ecu afterwards will just add to the cost.
i think ill have to go get the faults read or ill just be chasing my tail
