1995 ZX 1.9D Elation
My apologies, but this probably sounds like a really bone question:
The Haynes book says the head bolt undoing sequence is the opposite of the doing up; i.e., start at No 10 (cam sprocket end) and spiral in to the middle?
Also, would you undo (say) a quarter turn at a time, or is it OK to undo the bolt in one go?
Live each day as if it were your last; one day you will be right...
ZX head bolt undoing sequence...
RussellF97
- x 10
Phil
Indecision is the key to flexibility...
- x 5673
Re: ZX head bolt undoing sequence...
Undo ¼~½ a turn in turn until all are free and yes, removal in reverse of tightening order.
RussellF97
- x 10
myglaren: thanks very much...
Phil
- x 94
yep loosening is an ever decreaseing circle from either end realy, and tightening is ever increaseing circle starting from either of the two centre bolts,
regards malcolm
regards malcolm
RussellF97
- x 10
Thanks for your replies chaps; the head is now sitting on my bench.
Phil
