Xantia S2 clock illumination linked to stereo?
Gingerposer
x 6
Unread post by Gingerposer »
Just a quick question regarding the above.
I recently changed the (faulty) original cd player in my Xantia for an aftermarket Sony - I noticed that the clock and the steering wheel control buttons were no longer illuminated.
Today I fitted a set of patch leads to restore the steering wheel controls, work perfectly now and the buttons are illuminating - but the clock is still dark.
Is the clock illumination part of the same circuit as the steering wheel buttons, or is it independent ( and just a coincidence that the bulb has gone just now)?
If it is just coincidence and a blown bulb, how easy is the replacement procedure?
If it is part of the steering wheel control button circuit I guess I'll have to live without a lit clock, but at least I can control the stereo from the wheel (really like that function)
Ainslie
xf1ref
x 12
Re: Xantia S2 clock illumination linked to stereo?
Unread post by xf1ref »
The clock is illuminated on the same circuit with dashboard, if you remove the scale where are the buttons and the clock...on the back of clock you will see a light bulb.Change it because probably is burned.
